Hi guys, I’m new around here and just looking for a bit of advice.
I want to replace my current pc and I’m thinking about building my own if it would work out to be cheaper and worth the effort considering what I need it for.
I don’t really use my pc for anything particularly processor intensive but I do tend to use it for several things at once (listening to music, playing football manager, browsing the net, etc) and my computer just can’t handle all that any more.
As you can see I don’t really need anything too special and I’m sure most off-the-shelf setups would be fine for what I need but I don’t really want all the extra bells and whistles they throw in so I wanted you guys to help me spec up a system that would be suitable for what I want.
I don’t really want to spend loads because of the way I use it and I’ve got a monitor, mouse and keyboard that are ok for now. I guess I can budget up to around £350-£400 but I’d like to spend less if possible. I just want it to be able to do everything I want smoothly and to last for a while but I’m not really sure what the best setup for this would be (dual core, quad core, vista, xp etc) so any advice would be great.
Thanks
Thanks
