I current have a q6600, IP35, and 4gb OCZ HTC Reaper 8500 Ram
Now the whole CPU overclocking aspect, I understand perfectly.
But it seems I'm forced to keep my ram at around 950mhz (depends on what my FSB is, I've been playing with all sorts of different speeds to find the best speed/temp trade-off)
Now, I was under the impression my ram should do nearly 1200mhz? Do I need to up the voltage to achieve a higher clock on my ram? Or would I be better keeping my ram at a lower clock, and improving the timings? If so, to what, and do I need to adjust the voltage for this?
I've also seen people knocking their multiplier down to 8 and increasing the FSB even more, what is the advantage to this, is it anything to do with the Ram multiplier?
I hope I'm not asking a particularly common question, I did attempt a search, to no (specific) avail.
RAM ratio...
