Ok guys, i have an Antec 900 case, I am going to go W/C again, I have an asetek cpu/vga/nb cooling kit from when i had my old p4 socket 478. But have decided not to really use any of it, well perhaps the N/B block...
I am going for an i7, asus rampage II extreme, with the XSPC dual bay res and pump, going for the EK supreme block and back plate (LGA775) for the 1366 socket. Now I cannot decide which rad to go for.... I want to mount it internal perhaps removing the large top mounted fan to mount the rad there, as I have seen in some builds. Or try and squeeze it in the front of the case... but unsure as the HD caddies will be useless. I was thinking of a 240mm setup.
1) Swiftech MCR220-QP
2) TFC Xchanger 240
3) Alphacool Black Ice Xtreme II
4) Alphacool NexXxoS Xtreme II Radiator
5) Aqua-Computer XT 240 Radiator
Anyone got any install pics of a 240mm in an antec 900, Is the 240 over kill for just the cpu at the mo?
Other items, EK 1/4BSP - 1/2" tubing barbs. Using 3/8's tubing on the barbs.
I am going to try to utilise the asetek power supply to the pump. Or perhaps this is no longer needed.
2) TFC Xchanger 240
