So, I said a few weeks back I was going to start the modification of my Cooper S, so over the past couple of weeks i've done just that...
I'll start with last weekends mod, simple but makes a fair bit of difference to noise as well as a little extra throttle response.
1x K&N Ultrik Cold Air Intake to replace the standard Airbox - Certainly a bargain for £50 inc fitting from a mate!
Now the next mod is very much a Marmite mod, a lot of people say things like 'You don't need lights to change gear" etc etc (Fox I can hear you already!!) but for me I love the look of them, and to me it's made the dashboard a little different and because BMW are now discontinuing a lot of the R53 JCW Retro Kits as well as more mainstream parts, i've wanted one of these for ages but just never got around to doing it before I went into BMW the other week and they told me they didn't stock them anymore so I had to import this from the USA (One of their last ones i'm told) you can fit the R56 version to my shape but I prefer this one:
The JCW Gearshift Indicator Retro kit
it's set to around 6500rpm (7.2 is the actual rev limit) and can be changed as you want (Albeit that involves yanking the whole dash out) the kit was about 1.5hrs work to get in, I know a good auto electrician and he and I did it..
Next on the cards is the 15% Supercharger pulley reduction (Not going for the 17% as I cba upgrading my Intercooler) and then possibly a Miltek Exhaust.
Need to keep it on hold for the moment though as today my Manifold started leaking... I think the car was telling me something as I drilled it's dash to get the indicator in!!) so that's gotta be replaced first!
