Bit of guidance please
30 Jun 2006
im on the verge of upgrading to a 24" monitor from a 20inch so my native res will increase to 1920x1080.
my current card is a 5850 and im thinking of upgrading but i cant make up my mind tbh, i thought i was going to go for a 6950 2GB but ive read conflicting things, basically its not going to be a huge difference?
and also, should i be considering a 560ti at all? would that be a better choice?
i should also mention i dont have a choice of getting another 5850 in my system to crossfire (psu and mobo limitations)
thanks in advance!
Be wise and listen to the man!
If your unwise and you really really must, then the 560 ti can be had for ~£170, but you really should listen!:p
