bit of help have no idea whats wrong!!
11 Feb 2007
London / Essex
ok all this happend in the last 24 hours and I have no idea how so many things can fail at once
one of the SSD's has damaged sector the adaptec raid contoller craps out and needs to be taken off the motherboard and re-installed to get it working
Everest stability test stops stating "Warning: Hardware failure detected Test Stopped"
I now only have 3 SSD's installed but the PC is still having the above failure in Everest
I cant unrar copy anything keeps saying the files are currupt
the SSD's have my OS on them iv tried unraring on a normal sata hdd has the same probs, all the bits in the pc are not more then month old.
what do i need to do to find out whats wrong??
Could be a faulty power supply, can you remove or test with another psu.
Test RAM with Mem Test to check these are not giving you problems.
Try a fresh install on your SATA drive.
Erm, RJC's suggestions seems like the norm - lets see if any of these are at fault
Re your problem, were you running these in a RAID setup? if so was it onboard RAID, to me it sounds like the RAID has faile thats why its saying your files are corrupt. You should still be able to recover them, you'll just have to rebuild the RAID array, once you work out whats actually failed
