bit of help with dvdfab...
2 Jan 2009
Aus
bit of help with dvdfab and ImTOO DVD Ripper Platinum...
just tried it for the first time by ripping a small clip off a DVD and not sure about the results:
no idea what to do with this as the last piece of software i had (imTOODVD Ripper Platinum) you just ripped it and that was that, it was ready to play.
So what do i do with the above? i was expecting to have just 1 video file.
also, in dvdfab is there a way to set resolution and sound quality? you can select quality with a drop down box, the two options are dvd5 and dvd9. it says dvd9 is 100 quality with no compression. does this mean that it will be DVD quality on a HD tv?
Thanks,
Flare
thanks but that just confused me xD
windows media player wont play it, VLC will, quicktime wont...which is a pain because i need it to work with appletv (quicktime)
Edit: ive tried using imtoo DVD ripper platinum but no matter what i try audio and video are never in sync!:mad: can anyone give me some pointers??
Windows media player opens my .vobs fine :confused: Simply right click ,open with ,windows media player.Works fine.Maybe a codec issue?
the problem is though that i need quicktime/appleTV to to be able to play it, which they dont.
So basically i need a piece of decent software that will rip into .avi format or soemthing
