Bit of help with options I have
  • Thread starter Thread starter Sui
  • Start date Start date
Sui
Sui
24 Sep 2005
Brighton
Hi all,
Once again looking at getting some stuff so although not a frequent poster here I do like looking for advice from the forums as it always proves useful.
Currently, I am running;
i3 550 @ 4.20GHz with a Artic Cooling Freezer 7 on it
Gigabyte GA-H55M-UD2H (Micro ATX)
4 GB (2x2) Kingston HyperX Blu DDR3 PC3-12800C9 1600MHz Dual Channel
A 1tb and a 250gb HDD
XFX ATI Radeon HD 4850 512MB GDDR3
Antec p182
and a DVD drive.
Basically, my girlfriend is wanting a computer to play some games on, nothing hardcore but games such as WoW and other 'newish stuff', basically something that can run new games at acceptable settings. I'm also looking at upgrading my graphics card as it does struggle a bit with BF3/Skyrim etc and I guess that's the bottleneck.
The options that I can see are:
A) I sell her my processor/cooler/mobo/ram/250gb HDD/gfx card/DVD drive for around £200~ if that is fair and put that money towards getting myself components to replace the things I sold her with a budget of around £500.
B) I keep my computer as it is and just buy a new graphics card, and then my girlfriend gets something around the same quality as mine currently is and I can supply her with the graphics card. I'm not sure how much that would cost but if its <£400 then that would be acceptable.
Don't require monitors/OS.
What would you recommend in this situation, just buy her a cheapish new rig and just replace my graphics card, or give her my old parts and get myself slightly better parts? If you need any clarification with anything feel free to ask :).
If it was me i would most likely order this...
YOUR BASKET
2 x EVGA GeForce GTX 460 Superclocked *** 1024MB GDDR5 PCI-Express Graphics Card (01G-P3-1363-KR) £119.99 (£239.98)
1 x Gigabyte Z68XP-UD3 Intel Z68 (Socket 1155) DDR3 Motherboard £99.98
1 x Intel Core i3-2120 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £99.95
1 x Cooler Master Silent Pro Modular 600W '80 Plus Bronze' Power Supply £64.98
1 x Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £43.99
1 x Bitfenix Outlaw Gaming Case - Black £36.98
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £14.39
Total : £612.85 (includes shipping : £10.50).
I would donate the 250GB HDD in your rig to save her buying a HDD as they are still relatively expensive at the mo.
The 6850 is an option but i do prefer the EVGA 460 gtx.
http://www.anandtech.com/bench/Product/542?vs=539
Now check the speed of that EVGA 460 it's clocked at over 850mhz not the 695mhz in the benchmarks....i have one clocked at 900mhz in my HTPC and it runs BF3 on custom high-ultra settings at 50FPS on average.
The PSU is modular and has enough juice to run two 460s and the mobo itself is SLI/Xfire capable with all the Z series goodies as well. My thinking is you use one of the 460s initially when you decide to change it much later she could make very good use of it
http://www.anandtech.com/bench/Product/314?vs=330
I do realise the case is out of stock, this was merely to give you a rough idea of what i would consider doing.
P.S In BF3 there is HBAO ambient occulsion providing you use a nvidia card (i.e the shadows are much better on the nvidia card) and the nvidia card adds cuda support.
