Bit of info on Cooling Additives
20 Feb 2004
Hondon de las Nieves, Spain
Found this over on XS and figured i'd post it over hear to end a few arguements
Fact 1:
Ethylene Glycol and Propylene Glycol, are considered to be non toxic when consumed in small to medium dosages, while large amounts can result in nausea, convulsions, slurred speech, disorientation, and heart and kidney problems. VERY large dosages can result in renal failure and death, but such high dosages would only be incurred by intention ingestion of ridiculous amounts of it, such as drinking a gallon of Anti-Freeze.
Fact 2:
Polyethylene Glycol, Polypropylene Glycol, Ethylene Glycol and Propylene Glycol, are considered for most purpose to be essentially the same thing, and who’s chemical properties are nearly identical, as well has having identical effects on humans and cooling systems. In short, Zerex saying it uses Ethylene Glycol instead of Polypropylene glycol really doesn’t matter. They are essentially one in the same.
Fact 3:
The aforementioned Glycols are ionic compounds and when dissolved in water form slightly acidic solutions which conduct electricity (they are weak electrolytes), and in turn promote galvanic corrosion. Radiator fluid manufacturers add certain chemicals to counteract the electrolytic effect of the Glycols, thus stopping galvanic corrosion from occurring, but by themselves will cause corrosion.
Fact 4:
Glycols ONLY purpose in cooling systems is to increase waters boiling point and reduce its freezing point, with the lowest freezing point for Glycols being around -45C where the Glycol has a molar mass 430g/mol.
Fact 5:
Copper, copper sulfate, endothall, simazine, and diquat dibromide are all different active ingredients used Algaecides (products that kill Algae). You will notice that Copper is on the top of that list. That’s right folks. The main cooling component of your watercooling loop will kill most algae all by its lonesome. Some algae are immune to copper, and can be identified by their blue-green color. Also, diquat dibormide is essentially a stable liquid (in aqueous solution) form of bromine gas, which is used to kill various bacteria.
Fact 6:
If you are looking to gain a bit more performance out of your water, nonionic surfactants are the way to go. (Froogle: “nonionic surfactant” to purchase). Choose nonionic because they will not increase the conductivity of your coolant like ionic surfactants will, thus keeping your electronics as safe as possible in the unlikely case of a spill. Common nonionic surfactants include: alkyl polyglycosides, Alkyl ether sulfate, Amine oxide, and Linear alkylate sulfonate
Conclusion:
In a properly setup PC cooling system which contains no mixed metals, and uses copper/brass as the metal of choice, no coolant additives are required. Pure deionized water or distilled water will be your best choice, with a small amount of nonionic surfactant added for that extra .01C if your interested.
I should note that I have been running a system on pure distilled water for the past 10months with absolutley no ill effects. There has been no corrosion (All copper/brass/delrin/PVC), and no algae buildup what so ever. Alas the white buildup on the inside of the tubing is still present, to which no one has any real idea what it is yet
