- 28 Jan 2005
- Southport
Hi all I recently got myself a new pc which consists of the following:
E2160 @ 3.0Ghz 340FSB 1.4v
Tuniq Tower 120 CPU Cooler with Artic Silver
4x1GB Crucial Ballistix PC5300 @ 3-3-3-12 667Mhz 2.2v (trying for 4-4-4-12)
Gigabyte GA_P35C_DS3R
Radeon 2900XT
P182 Case
500GB HDD
Now as you can see Ive overclocked a fare bit
Now I can get it running stable with the memory at stock (3-3-3-12 667mhz 2.2v) but with the slightest increase it blue screens. Now i had a little look around in the case and the memory was absolutely roasting
I take it this is what is my problem. My CPU runs at 60oc at the very most
Another question is that as soon as a stick the CPU up to 3.1Ghz 1.425v I get this in orthos:
1:Test 1, 560000 Lucas-Lehmer iterations of M212991 using 10K FFT length.
1:FATAL ERROR: Rounding was 0.5, expected less than 0.4
1:Hardware failure detected, consult stress.txt file.
1:Torture Test ran 16 minutes 55 seconds - 1 errors, 0 warnings.
I have not stress.txt to view either. Anyone shed any light on this?
Radeon 2900XT
P182 Case
500GB HDD
