it was going to be a start up script as nobody here turns their machines off at night.
As the script is a computer start up script I would not have thought the logon script settings would affect it?
The script is taken from microsoft in their article about rolling out office through gpo start up scripts, as below
setlocal
REM *********************************************************************
REM Environment customization begins here. Modify variables below.
REM Get ProductName from the Office product's core Setup.xml file, and then add "office14." as a prefix.
set ProductName=Office14.PROPLUS
REM Set DeployServer to a network-accessible location containing the Office source files.
set DeployServer=\\FS\Office2010SourceFiles
REM Set ConfigFile to the configuration file to be used for deployment (required)
set ConfigFile=\\FS\Office2010SourceFiles\ProPlus.WW\config.xml
REM Set LogLocation to a central directory to collect log files.
set LogLocation=\\FS\Office2010LogFiles
REM Deployment code begins here. Do not modify anything below this line.
IF NOT "%ProgramFiles(x86)%"=="" (goto ARP64) else (goto ARP86)
REM Operating system is X64. Check for 32 bit Office in emulated Wow6432 uninstall key
:ARP64
reg query HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432NODE\Microsoft\Windows\CurrentVersion\Uninstall\%ProductName%
if NOT %errorlevel%==1 (goto End)
REM Check for 32 and 64 bit versions of Office 2010 in regular uninstall key.(Office 64bit would also appear here on a 64bit OS)
:ARP86
reg query HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\%ProductName%
if %errorlevel%==1 (goto DeployOffice) else (goto End)
REM If 1 returned, the product was not found. Run setup here.
![Big Grin :D :D](/styles/default/xenforo/vbSmilies/Normal/biggrin.gif)
eployOffice
start /wait %DeployServer%\setup.exe /config %ConfigFile%
echo %date% %time% Setup ended with error code %errorlevel%. >> %LogLocation%\%computername%.txt
REM If 0 or other was returned, the product was found or another error occurred. Do nothing.
:End
Endlocal
As i mentioned it works fine but it runs in the background which is no good as it will fail if people have any office applications automatically open when logging on etc
