Bit torrent client for vista
Caporegime
25 Jul 2005
Canada
Anyone know of any bit torrent client that runs on vista and allows aero to still work. I usually use Bitlord but it isnt compatable with aero. (I'm a sucker for looks ;) )
pinkegobox said:
glad to hear it :D consider yourself enlightened
/torrent-client-fanboyism-mode-OFF
you wont want to hear the next bit then. ;)
I installed utorrent and it didn't seem to want to work properly (probably just me) so I tried bitlord and works with vista (and aero), not sure why it didn't before :o . Its also downloading at higher speeds. :D
Least yer know you can still get yer porn.
Nope thats what limewire's for. ;)
Yeah I don't think it was the client as such it was just a single file that still won't delete. I go into the folder it is in and the entire computer grinds to a halt and explorer starts using 100% of the cpu. I did a quick fix by moving everything else out of the folder but I still cant delete it annoingly. Any ideas?
utorrent all the way!!!
I was a big fan of azureus until a mate pointed this out, now this is all I use with my Vista RC1 O/S
The Aero breaking of Azureus et al. is a fault of Java being non-Aero friendly. Instally the JRE 6 Beta instead of JRE 5, and all will be well.
Azureus>uTorrent
only advantage of uTorrent is that standalone client that doesn't need installing
other than that, Azureus prawns it
