Bitcomet - Port Forwarding seems to have stopped
19 Jan 2003
Bristol, UK
I have the BitComet listen port enabled for forwarding on my Linksys router and Windows firewall.
However, all my connections are "local".
It has been running fine and just started to behave like this.
Any ideas why?
I swapped the router out for a Netgear router a customer gave me the other day.
This router seems faster than the Linksys and also port forwarding is now working.
Odd problem but seems cured now.
You shouldnt have had any issues really if you were using windows firewall..
You only need one firewall enabled, portforward with the router FW on and that's all you need, don't use UPNP either but manually choose *** default port to forward
