OcUK Staff
- 26 Nov 2014
- Stoke
OCUK and Bitfenix are pleased to launch the Bitfenix Aegis Micro-ATX Chassis. The Aegis features a beautiful rounded shield-inspired front and supports an impressive amount of fans and radiators: up to 8 120mm fans or 5 140mm fans, dual 280 radiators or a 360 and 240 combo.
They are available with the innovative programmable Bitfenix ICON™ Display or in 'Core' variety with the Bitfenix Aluminium logo. They are also available in five different colours: - Black, White, Yellow, Red and Blue.
As they are geared towards watercooling setups, the Aegis also comes bundled with reservoir & pump brackets, a PSU shroud cover (which can be removed for up to 220mm support) and support for 380mm VGA cards.
Stock is due around 5th March, so get your preorders in now
Bitfenix Aegis Micro-ATX Chassis w/ Icon Programmable Display - Black @ £79.99 inc VAT
AEGIS features a beautiful rounded shield-inspired front with the same ICON logo display we use on Pandora, and a sporty fresh design all around. It comes in black, white and 3 vibrant colors (red, blue, yellow) and supports an impressive amount of fans and radiators: up to 8 120mm fans or 5 140mm fans, dual 280 radiators or a 360 and 240 combo.
The 3 tool free storage cages are modular and can be moved around or taken out all together, in which case there is still a hidden 2.5" slot behind the PSU and a "show off" 2.5" slot next to the mainboard tray. Besides some nice dust filters on the top, front and bottom, it comes with a built in fan controller, a stylish PSU cover, a rubber padded pump bracket and last but not least a neat reservoir bracket, that let users attach a reservoir or pump/res combo to a 240 or 360 radiator.
Features
- Bold yet Timeless design - Beautiful smooth lines
- Large top panel to channel airflow and block noise
- Closed front panel with large side vents to block noise
- Programmable Bitfenix ICON™ Display - 2.8” diameter, 240 x 320 colour resolution, Connects to internal USB header.
- Available in black, white and 3 vibrant colours
- Mixed colour internals, not just plain black or white
- Huge Sidepanel Window
- Removable PSU Shroud Cover
- Massive Backplate Access for High-End CPU coolers
- Supports 380mm GPU's
- 5 PCI slots for optimum Dual GPU support
- Removable Toolless 2.5"/3.5" bays
- Up to 220mm PSU support
- Up to 8 fans support
- Integrated Fan Controller
- Magnetic Dust Filters
- Supports up to 360mm radiators
- Comes with bundled reservoir and pump brackets
Specification
- Materials: Steel Alloy, Polymer, Acrylic (window)
- Colours: Black/Black
- Case Dimensions (mm/in): 205 x 470 x 480 (WxHxD) - 7.95 x 18.15 x 18.38 (WxHxD)
- Box Dimensions (mm/in): 255 x 530 x 505 (WxHxD) - 10.03 x 20.86 x 19.88 (WxHxD)
- Box Volume: 2.4 ft³/cuft - 68.25L - 0.068m³
- Case Weight (kg/lbs): 6.7 / 14.8
- Box Weight (kg/lbs): 7.8 / 17.2
- Max Heatsink height (mm/in): 170mm / 6.7
- Max AIO support (push/push pull): 360 / 360
- Max radiator support (push/push pull): 360 (85mm) + 240 (60mm) / 360 (60mm) + 240 (60mm)
- Max VGA length (mm/in): 380mm / 14.9 with HDD cage installed (depends on front radiator configuration)
- Motherboard: Micro ATX, Mini-ITX
- ICON™ Display: 2.8" TFT, 240 x 320
- 3.5” Drive slots: 4 (two removable cages with 2 tool less slots each)
- 2.5” Drive slots: 4 (one removable cage with 2 tool less slots each, one slot next to the Mainboard, one slot behind the PSU)
- Max HDD capacity: 40TB (4x 8TB 3.5” + 4x 2TB 2.5”)
- Max SSD capacity: 16TB (8x 2TB 2.5”)
- Fan Controller: 4 fan headers, 3 speeds (12v, 7v, 5v) with 3 indicator LEDs (white)
- Cooling Top: 3x 120mm or 2x140mm – click on dust filter
- Cooling Front: 3x 120mm or 2x140mm – magnetic dust filter
- Cooling Bottom: 1x 120mm – magnetic dust filter
- Cooling Bottom: 1x 120mm (included)
- PCI Slots: 5
- I/O: USB 3.0 x 2, Audio, Mic, Power, Reset, Power LED (white), HDD LED (white)
- PSU: PS2 ATX, up to 220mm in length, intake from case interior or case bottom
- Special Features: ICON™ Display, Fan Controller, PSU cover, Magnetic Dust Filters, Pump bracket, Reservoir Bracket, 2 Removable HDD Cages, 1 removable SSD cage, Tool less HDD and SSD system, Hidden 2.5” slot, 2.5” Show Off slot, Window Sidepanel, Rubber Grommets.
Only £79.99 inc VAT.
ORDER NOW
Bitfenix Aegis Micro-ATX Chassis w/ Icon Programmable Display - White @ £79.99 inc VAT
ORDER NOW
Bitfenix Aegis Micro-ATX Chassis w/ Icon Programmable Display - Red @ £79.99 inc VAT
ORDER NOW
Bitfenix Aegis Micro-ATX Chassis w/ Icon Programmable Display - Blue @ £79.99 inc VAT
ORDER NOW
Bitfenix Aegis Micro-ATX Chassis w/ Icon Programmable Display - Yellow @ £79.99 inc VAT
ORDER NOW
Bitfenix Aegis Core Micro-ATX Chassis - Black @ £69.95 inc VAT
AEGIS Core features a beautiful rounded shield-inspired front and a sporty fresh design all around. It comes in black, white and 3 vibrant colors (red, blue, yellow) and supports an impressive amount of fans and radiators: up to 8 120mm fans or 5 140mm fans, dual 280 radiators or a 360 and 240 combo.
Features
Specification
- Motherboard Micro ATX, Mini-ITX
- PCI Slots: 5
- Special Features: Aluminium Bitfenix Logo sticker, Fan Controller, PSU cover, Magnetic Dust Filters, Pump bracket, Reservoir Bracket, 2 Removable HDD Cages, 1 removable SSD cage, Tool less HDD and SSD system, Hidden 2.5” slot, 2.5” Show Off slot, Window Sidepanel, Rubber Grommets.
Only £69.95 inc VAT.
ORDER NOW
Bitfenix Aegis Core Micro-ATX Chassis - White @ £69.95 inc VAT
ORDER NOW
Bitfenix Aegis Core Micro-ATX Chassis - Red @ £69.95 inc VAT
ORDER NOW
Bitfenix Aegis Core Micro-ATX Chassis - Blue @ £69.95 inc VAT
ORDER NOW
Bitfenix Aegis Core Micro-ATX Chassis - Yellow @ £69.95 inc VAT
ORDER NOW
Features
Specification
- PCI Slots: 5
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
Features
Specification
- PCI Slots: 5
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
