OcUK Staff
We're happy to introduce the new Bitfenix Alchemy 2.0 DIY Cable range. Available in 10 different colours, with 20cm/40cm & 60cm size variants, these kits allow you to choose exactly which combination of colours you want on the braided cables in your system. Extending the customizability of pre sleeved cables, BitFenix introduces the Alchemy 2.0 individually sleeved wires, precision moulded connectors and cable combs. This enables the user to create extensions in unique styles to fit a variety of build themes.
The Alchemy 2.0 range sets itself apart from the competition with a few key areas: -
- Connectors: Injection moulded using special rubber materials for increased durability and ease of use, better than just straight up plastic connectors.
- Cables: 16AWG pure copper cables, packaged in sets of 5, heatshrinkless sleeving process for a premium finish every time.
Installation is pretty simple and clearly explained on the products, resulting in quick and easy braided cables to suit your exact requirements. Added to that, the pricing is pretty aggressive considering what you are getting. Whilst I don't have a firm ETA for these, rough ETA is in around 3 weeks.
Here's a small selection of whats available, with a link to the full range below
BitFenix Alchemy 2.0 PSU, 20+4 Pin ATX Connector Pack - Black @ £2.29 inc VAT
Alchemy 2.0 precision moulded connectors provide smoothly fitting cable extensions to make your modding project quick & easy. Each pack consists of a plug (male) and a socket (female). The connectors are injection moulded using special rubber materials to improve the durability and ease of use. Alchemy 2.0 Connectors are designed to be used with high performance wires up to 16AWG with high current alloy terminals.
Certified by CUL and TUV, Alchemy 2.0 connectors are proven to be reliable and safe to use in computers giving you peace of mind. These connectors have a wide operating temperature from -40 to 105°C.
Specifications
- Model: BFX-ALC-24CONMBKK-RP
- Type: 20+4 Pin ATX Connector Pack
- Contents: 1 x Male 20+4 Pin Connector, 1 x Female 20+4 Pin Connector
Only £2.29 inc VAT.
ORDER NOW
BitFenix Alchemy 2.0 PSU Cable, 5x 60cm - Orange @ £4.19 inc VAT
Presented in ten different colours, Alchemy 2.0 individually sleeved wires aim to provide the ultimate customizability in sleeving. They are manufactured to the highest quality to provide unparalleled performance and stable power delivery. Aimed at high performance power supplies, Alchemy 2.0 cables are manufactured with high quality components to support up to 1600W units.
Use of High Current Alloy Terminals improves the connection and minimizes the efficiency drop in modular cables. Use of Pure Copper cables with thicknesses up to 16AWG reduces the resistance while increasing the efficiency throughout.
Alchemy 2.0 cables are sleeved to perfection with high density sleeving in a heatshrink-less sleeving process. Using special cables, the flexibility has been improved to extend the durability of the cables. These premium sleeved cables come in 20cm, 40cm and 60cm lengths to perfectly suit your build.
Specifications
- Model: BFX-ALC-60CMLO-RP
- Type: PSU Cable, 5x 60cm - Orange
- Contents: 5 x Alchemy 2.0 60cm Orange sleeved wires
Only £4.19 inc VAT.
ORDER NOW
BitFenix Alchemy 2.0 PSU Cable, 5x 40cm - Red @ £3.59 inc VAT
Only £3.59 inc VAT.
ORDER NOW
BitFenix Alchemy 2.0 PSU Cable, 5x 20cm - NV Green @ £2.99 inc VAT
Only £2.99 inc VAT.
ORDER NOW
BitFenix Alchemy 2.0 PSU Cable, 5x 60cm - Grey @ £4.19 inc VAT
Only £4.19 inc VAT.
ORDER NOW
CHECK OUT THE FULL BITFENIX ALCHEMY 2.0 DIY CABLE RANGE HERE!
Specifications
Only £2.29 inc VAT.
ORDER NOW
Specifications
Only £4.19 inc VAT.
ORDER NOW
Only £3.59 inc VAT.
ORDER NOW
Only £2.99 inc VAT.
ORDER NOW
Only £4.19 inc VAT.
ORDER NOW
