BitFenix Alchemy cables and Fractal Design R3 case
17 Dec 2004
Im thinking about getting the window panel for my R3 and then BitFenix Alchemy red power cables to match the colour of my psu and gpu. But Will I be able to get the right side panel on, like at the moment I have a job to get it on?
Heres both sides of my case
Or would white cables look better:confused:
I had a little problem getting my right side of my Shinobi on. and I am planning on getting BitFenix extension...
What I find helps the most is making sure the cables aren't overlapped a lot and spread around the whole case (well behind the mobo tray) This helps keep the cables as flat as possible etc...
The biggest problem I find is the 24pin. Like you I run a Corsair HX PSU (mines 650w, only difference) and the 24pin cables are all bundled together making them quite bulky. I try and give thaty it's own route with the least cables going over and under it. After I done this, it was easier to get the panel on.
Just try and spread the cables around abit and take your time making it look good behind the mobo tray, sounds stupid but if it looks tidy, then chances are... it's nice and flat to the tray too :)
EDIT: also, get that 8pin cable put behind the mobo tray!! Will look much better :D
Hope that helps,
Cam.
