Bitfenix alchemy cables problem
5 Oct 2011
Hi guys,wasnt sure where to post this,but i also have a problem with one of my pci-e 6pin extension cables,although the problem is of a different nature,the braiding has come off at the connector bit,which kinda ruins the look :(,i've tried stuffing it in to the connector but it just wont stay.
Here's a pic to show you what i mean
Apart from this these cables are looking awesome in my case,hopefully this is a one-off as i plan to get me the 8 pin power connector and some sata ones,and probably some molex to sata too.
Is there an easy fix for this anyone?
Remove the terminal using two half straightened staples, push the braid up to the terminal and push it in as best you can, then add a dab of super glue to hold it in place. I had one I used go the same way.
Well to be fair it wasnt like that when they arrived,but i didnt do anything unusual to them lol,i just obviously bent the cable round towards the back of my case and that individual cable's braid came loose,was hopefully a one-off,and unsure as to rma possibility,hopefully Kul1 reads this and can advise me further,although he did say in another thread to give bitfenix support a shout if you have any problems with these cables
EDIT:sent an email to bitfenix support who were more than happy to send a replacement out,so pretty pleased with that.
