** BITFENIX AURORA & ALCHEMY 2.0 RGB LED STRIP KITS - ALL THE THINGS HAVE BEEN RGB'ED **
OcUK Staff
26 Nov 2014
Stoke
We're very happy to introduce the Bitfenix Aurora Midi Tower Chassis with Bitfenix RGB Chroma Control & Bitfenix SSD Chroma - both of which are certified by Asus Aura. The Aurora is available in Black & White and comes with a pair of tempered glass windows as standard, the left being perfectly clear to showcase your system, and the right side is heavily tinted to hide any sub-tier attempts at cable management :) The end result looks great and stands out somewhat from the current market.
The Aurora can support up to 280mm radiators on the top and front of the chassis, E-ATX motherboards, 400mm VGA cards & 220m PSU's for comprehensive hardware installation. By far the most impressive feature of the Bitfenix Aurora is the RGB SSD Chroma which illuminates the installed SSD in whichever colour you prefer! Even if you don't install an Asus Aura compatible motherboard, the Aurora can cycle through 7 pre-set colours with a pulse mode.
In addition we're pleased to launch the Bitfenix Alchemy 2.0 RGB LED Strip Kits, available in 30cm or 60cm varieties, with or without an RGB controller. These strips are also Asus AURA certified for compatibility with all Asus ROG motherboards. They feature Bitfenix TriBright LED's for superior colour correction & saturation, whilst maintaining a brighter output than normal RGB LED's.
The RGB LED strips also feature molex connectors for safer operation and durability as standard, allowing safe daisy chaining up to 1.8M per molex power connector, which can be an issue for LED strips using SATA connectors. The RGB controller is able to independently cycle through 7 pre-set colours with a pulse function, even if the motherboard has no RGB compatibility.
Stock on both the Aurora and the RGB LED Strip kits will arrive with us around the start of September, so preorder now!
Bitfenix Aurora Midi Tower Case - Black Window @ £86.99 inc VAT https://www.overclockers.co.uk/bitfenix-aurora-midi-tower-case-black-window-ca-226-bx.html
Aurora is designed for high end aesthetically pleasing builds with water-cooled systems carrying an elegant theme of curved lines and glass windows
Only £86.99 inc VAT.
ORDER NOW
Bitfenix Aurora Midi Tower Case - White Window @ £86.99 inc VAT https://www.overclockers.co.uk/bitfenix-aurora-midi-tower-case-white-window-ca-227-bx.html
Aurora is designed for high end aesthetically pleasing builds with water-cooled systems carrying an elegant theme of curved lines and glass windows.
ORDER NOW
Bitfenix Alchemy 2.0 Magnetic RGB LED Strip - 30cm @ £17.99 inc VAT https://www.overclockers.co.uk/bitfenix-alchemy-2.0-magnetic-rgb-led-strip-30cm-cm-358-bx.html
Alchemy 2.0 Magnetic RGB LED-strips are high quality and certified by “ASUS AURA”. They come in two lengths, 30cm and 60cm with the option to choose a kit with or without the controller.
Only £17.99 inc VAT.
ORDER NOW
Bitfenix Alchemy 2.0 Magnetic RGB LED Strip - 60cm @ £21.95 inc VAT https://www.overclockers.co.uk/bitfenix-alchemy-2.0-magnetic-rgb-led-strip-60cm-cm-359-bx.html
Only £21.95 inc VAT.
ORDER NOW
Bitfenix Alchemy 2.0 Magnetic RGB LED Strip + Control Box - 30cm @ £21.95 inc VAT https://www.overclockers.co.uk/bitf...rgb-led-strip-control-box-30cm-cm-35a-bx.html
ORDER NOW
Bitfenix Alchemy 2.0 Magnetic RGB LED Strip + Control Box - 60cm @ £25.99 inc VAT https://www.overclockers.co.uk/bitf...rgb-led-strip-control-box-60cm-cm-35b-bx.html
Only £25.99 inc VAT.
ORDER NOW
Why is a molex connection considered safer than sata for power?
Bitfenix said:
Most SATA connectors have +12v pins that are only 0.6mm thick, allowing 1.5A of +12V current, which is only good for 1.8m of LED strips and also decreases the product lifetime due to voltage decline. Bitfenix instead use Molex connectors due to the 2.1mm thick +12V pin, allowing 7A of +12v current which ensures safety and durability.
I wouldn't want anything like as much as 1.8m of LEDs, I'd have prefer a sata connection to help with a tidier build
Get one of these then:
Can't they just use 8-pin EPS connectors so I can have 35m of LED's, seriously rag tag.
JR
