19 Oct 2013 at 10:42 #1 Addicted Addicted Soldato Joined 23 Jul 2007 Posts 2,823 Location Worcester So, I ordered 3 cables: 1x CPU 8-pin 2x PCI-E 8-pin All 3 of the cables are BFA-MSC-8EPS46RKK-RP Anyone know if that's ok? The cables are identical, but not sure if I just got a dodgy order? Cheers
19 Oct 2013 at 10:47 #2 snips86x snips86x Soldato Joined 14 Nov 2012 Posts 17,985 Location Chesterfield Are you saying you received 3 8pin EPS cables? Looking at the connecting ends of them, they look different so not sure they would work.
19 Oct 2013 at 10:47 #3 Addicted Addicted Soldato OP Joined 23 Jul 2007 Posts 2,823 Location Worcester Yep, you're right, they're 2 different cables. Sigh. Had to use a competitor as OcUK are out of stock, not sure why I bothered, 2nd support ticket for the same order so far.. Last edited: 19 Oct 2013
