Bitfenix Colossus Case Question
16 Nov 2011
On the striped version are the lights on the side in the case or in the side panel?
Basically thinking I would like a windowed case but like the idea of being able to have pulsing lights - sounds silly but little things for little people
i had the same dilemma myself i went for windowed in the end as its a shame to hide my shiny new parts lol, you get the 2 230 mm fans with green led or other colours and i changed them all foe spectre pros as it was getting hot, i also added the window fans x2 and got a 140mm for rear exhaust all green led and its lit up like black pool in there show casing all the good stuff windowed all the way ;)
defo up the fans to spectre pros as standard ones dont move much heat the pros on the other hand made a huge difference
