bitfenix colossus fan direction
21 Jan 2012
Hereford, UK
Hi guys case fans question
I have a bitfenix colossus case and I have 230mm sucking in
front 2 120mm in bottom sucking in
Side 120mm blowing on gpu
Rear 140mm exhaust
And 230mm top exhaust
My question is this is this correct flow for case I know cool in thdn rises and exhaust out rear and top but I was told to have top blowing in so I get positive flow????
So should I switch top to blow in and what is positive flow and will it help temps?
Any help much appreciated :D
There's much to case cooling. This might help give you some ideas.
The only way to know what works best in your case (no pun) is test different combinations and see.
There is much more to cooling than good cases, good fans and good CPU / GPU coolers. Modern GPU's make more heat than CPU... and getting that heat out of the case can be a challenge.
Setting up the case to cool properly is the hardest and most time consuming part of a build... And the most neglected by most builders.
Cases, especially those with filters, usually benefit from fans with higher static pressure ratings than stock fans... "cooler" fans instead of "case" fans.
Intakes are typically more restricted than exhaust; air filter, more restrictive grill, HDD cage, etc. I prefer a little more intake than exhaust.
And don't confuse number of fans with amount of airflow... or cofuse airflow with airblow
Airflow is flowing cool air from intake to component and flowing hot air from component out of case without the hot air mixing with the cool air.
Airblow is lots of fans blowing air with some of hot air from components mixing with cool air making it warmer resulting in warm air not cooling components as well as the cool air will.
Putting fans in case as intake and/or exhaust is only the first step. These fans only move air in and out of case.
This does not mean heated air is not mixing with cool air.
Nor does it mean cool air is going to where it is needed.
Getting the air to flow inside of case properly is even more important. We still need to manage where the air flows inside the case. We can do this several ways; deflectors, cooler intake fans, exhaust fans, removing vent grills, using fans with higher pressure/airflow, building ducts to or from CPU/GPU cooler, etc.
Using a remote temperature sensor to monitor what air temps are is the key to finding out where the cool air is flowing and knowing heated air is not mixing into it. By monitoring this we can than make changes to get airflow the way we want it.
I monitor the temps with a cheap indoor/outdoor wired remote or terrarium digital thermometer. Twist a piece of stiff insulated wire into the last 8" of sensor lead so you can bend it to position sensor where you want it... like 40mm in front of your GPU cooler/radiator intake.. to see what the air temp going into CPU / GPU cooler is compared to room temp. The closer it is to room temp the better.. Shouldn't be more 5c maximum, 2-3c is what I usually end up with after 30 minutes full load on both CPU and GPU.
yeah true that not as simple as slap in loads of fans i just wanted to know if anyone use top fan to blow in for this posative air jargon i hear but i have decided to take the watercooling plunge so rad will be going up there now i had a itch that wouldn't budge only way was to go water thanks for your reply though
Wouldn't having fans on rad exhausting suck hot air through rad causing temps to go up
I have a 240 in front on intake and the other in top but I was told to have top rad sucking in so cool air goes through rad?
This is the whole airflow vs airblow argument, if you have your tops fans pulling in cool air from outside the case and over the rad, the top rear fan can exhaust the air out as it comes in. Effective airflow would be cool air in from the front and top and out through the rear or wherever without hitting too many heat critical components on the way out.
I know everyone loves the heat rises argument too.
But as Doyll's link says, try different setups, what works in your scenario may not work for someone else.
Water temps will only be higher with rad as exhaust if there are components giving off a lot of heat which aren't included in the loop (eg. CPU-only loop)
On the other hand, if the rad is intake then everything which isn't watercooled will be marginally hotter, as the air inside the case will have been heated on its way in.
If you have the freedom to choose without problems, then judge it based on which components need the extra degree or two of cooling. Otherwise go with whichever has the smoothest tubing run for minimal flow restriction.
