BitFenix Ghost Silent Tower Case
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys.
We are proud to announce the launch of the new BitFenix Ghost Tower Case. This chassis offers optimal noise dampening combined with a modern and stylish minimalistic look. Stock is due to land the end of September.
BitFenix Ghost Silent Tower Case - Black @ £89.99 inc VAT
Ghost begins with a modern minimalistic look that blends into virtually any decor. Its clean lines are supported by a single silver arch, the shape of which is mirrored perfectly by the front door vents. Coating the outside is a new surface treatment from BitFenix dubbed NanoChrome™. This specially developed coating combines an enamel with mother-of-pearl powder, which is then applied to the surface of the case and heated to high temperatures. The result is a uniform finish that perfectly blends together both plastic and metal parts.
Opening the front door reveals BitFenix Serenitek™ silencing material. Dense yet light weight, Serenitek covers the inside of both the front door and the two side panels to help trap unwanted noise inside the chassis. The door itself is a dual hinge design, which allows users to open the front door from the left or from the right on-the-fly. Up top are two USB 3.0 and two USB 2.0 ports, as well as the BitFenix S4™. This compartment is equipped with a hot-swap bay that features a high speed SATA III port, making it ideal for transferring data from hard disks and SSDs without having to open up the case. Best of all, removing the top fan filter reveals a cavernous compartment designed to accommodate a slim 240mm radiator, making Ghost a perfect foundation for a silent water cooled rig of destruction. On the bottom of the case, you'll find a handy magnetic dust filter, as well as dual rails that are designed for BitFenix Alchemy LED Strips. Simply affix the LED strips to these rails, route the power cables through the pre-drilled holes in the steel body, and you've got an impressive under lighting effect in no time at all.
On the inside, Ghost delivers other impressive features that help keep noise to a minimum. Dual 120mm Spectre fans move air through the case while remaining whisper quiet, and anti-vibration HDD trays help muffle rotating hard disks. Rubber grommets help reduce sound caused by air turbulence and rubber padding for the PSU helps keep PSU noise down. Ghost users will also find a specialized SSD rack that not only allows the installation of up to three 2.5" SSDs, but also allows for graphics cards up to 330mm in length without any modifications! Tool-free drive locking mechanisms make ODD and HDD installation a snap, while a massive CPU cooler cutout enables quick swapping of CPU coolers.
-Materials: Steel / Plastic
- Dimensions (WxHxD): 210 x 522 x 510mm
- Motherboard Sizes: Mini-ITX, mATX, ATX
- 5.25" Drive Bays: x 3
- 3.5" Drive Bays: x 4
- 2.5" Drive Bays: x 3 dedicated, x 7 total
- Hot Swap Bay: x 1
- Cooling Front: 1 x 140mm or 2 x 120mm (1 x 120mm included)
- Cooling Rear: 1 x 120mm (included)
- Cooling Top: 1 x 230mm or 1 x 200mm or 2 x 140mm or 2 x 120mm (optional)
- Cooling Bottom: 1 x 140mm or 1 x 120mm (optional)
- PCI Slots: x 7
- I/O: 2 x USB3.0, 2 x USB2.0, HD audio, SATA III hot swap bay
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: Serenitek™ silencing material, S4™ Hot Swap and Storage, NanoChrome™ surface treatment, filtered intakes, tool-free drive locking.
Only £89.99 inc VAT.
ORDER NOW
Very smart and minimalist looks. I like it. Good that the HDD caddies are mounted sideways now and they've added grommets to the cable management holes :)
Shame it's not Softouch-ed. That would have made it look even meaner.
Excellent price too!
I am very interested in this case, largely due to the noise area, can't stand noisy cases, will be interesting to see how the cooling is though as generally silent cases aren't always the best for temps.
Looks great and a great price to, nice one bitfenix.
offical vid here
Good to see you can get a 230mm spectre fan up top.
But thin rads in a 'silent' branded case - XSPC will be pleased - EX280 bundle anyone.
and £10 more than the Fractal Design Define R3...
hi all ,thinking of a new case for my new build the case looks grt... but will it come with a clear side window amswers please if poss
Looks like it has the potential to be a very good case for silent builds, hope it lives up to the hype.
One thing; if it is 210mm wide, how is it possible to fit a 230mm fan in the top? :confused:
Definitely going to be my next case. Currently using a BitFenix Merc Beta so this will be a nice upgrade.
Shame the 2.5" cage isn't removable but still an awesome case!
ooo so tempting if only i hadn't upgraded to a shinobi at christmas and sadly had to live on a student budget
Our 230mm fan's dimensions are 200x230x30.
P.S 2.5" cage IS removable.
