BitFenix Ghost Silent Tower Case
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys.
We are proud to announce the launch of the new BitFenix Ghost Tower Case. This chassis offers optimal noise dampening combined with a modern and stylish minimalistic look. Stock is due to land the end of September.
BitFenix Ghost Silent Tower Case - Black @ £89.99 inc VAT
Ghost begins with a modern minimalistic look that blends into virtually any decor. Its clean lines are supported by a single silver arch, the shape of which is mirrored perfectly by the front door vents. Coating the outside is a new surface treatment from BitFenix dubbed NanoChrome™. This specially developed coating combines an enamel with mother-of-pearl powder, which is then applied to the surface of the case and heated to high temperatures. The result is a uniform finish that perfectly blends together both plastic and metal parts.
Opening the front door reveals BitFenix Serenitek™ silencing material. Dense yet light weight, Serenitek covers the inside of both the front door and the two side panels to help trap unwanted noise inside the chassis. The door itself is a dual hinge design, which allows users to open the front door from the left or from the right on-the-fly. Up top are two USB 3.0 and two USB 2.0 ports, as well as the BitFenix S4™. This compartment is equipped with a hot-swap bay that features a high speed SATA III port, making it ideal for transferring data from hard disks and SSDs without having to open up the case. Best of all, removing the top fan filter reveals a cavernous compartment designed to accommodate a slim 240mm radiator, making Ghost a perfect foundation for a silent water cooled rig of destruction. On the bottom of the case, you'll find a handy magnetic dust filter, as well as dual rails that are designed for BitFenix Alchemy LED Strips. Simply affix the LED strips to these rails, route the power cables through the pre-drilled holes in the steel body, and you've got an impressive under lighting effect in no time at all.
On the inside, Ghost delivers other impressive features that help keep noise to a minimum. Dual 120mm Spectre fans move air through the case while remaining whisper quiet, and anti-vibration HDD trays help muffle rotating hard disks. Rubber grommets help reduce sound caused by air turbulence and rubber padding for the PSU helps keep PSU noise down. Ghost users will also find a specialized SSD rack that not only allows the installation of up to three 2.5" SSDs, but also allows for graphics cards up to 330mm in length without any modifications! Tool-free drive locking mechanisms make ODD and HDD installation a snap, while a massive CPU cooler cutout enables quick swapping of CPU coolers.
-Materials: Steel / Plastic
- Dimensions (WxHxD): 210 x 522 x 510mm
- Motherboard Sizes: Mini-ITX, mATX, ATX
- 5.25" Drive Bays: x 3
- 3.5" Drive Bays: x 4
- 2.5" Drive Bays: x 3 dedicated, x 7 total
- Hot Swap Bay: x 1
- Cooling Front: 1 x 140mm or 2 x 120mm (1 x 120mm included)
- Cooling Rear: 1 x 120mm (included)
- Cooling Top: 1 x 230mm or 1 x 200mm or 2 x 140mm or 2 x 120mm (optional)
- Cooling Bottom: 1 x 140mm or 1 x 120mm (optional)
- PCI Slots: x 7
- I/O: 2 x USB3.0, 2 x USB2.0, HD audio, SATA III hot swap bay
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: Serenitek™ silencing material, S4™ Hot Swap and Storage, NanoChrome™ surface treatment, filtered intakes, tool-free drive locking.
Only £89.99 inc VAT.
ORDER NOW
This looks really nice, solid, and a step up from the Shinobi. I'd give this a whirl if I hadn't recently bought the said shinobi!
Any in-action shots for us with this as the case?
whats the nanochrome, they not doing soft touch on this 1?
a lot to like about it tho
would look nice in different colors as it does have a door^^
Another very nice case from Bitfenix, theyve really got a knack for producing well thought out, attractive cases at very good prices.
ok, decision time. I want a new case and am torn between this and the corsair 550D. I want to put in a cpu wc loop and can't decide which case would work better/easier. Any ideas guys?
Looks like it might be a nice case.
Interesting how it was announced 3 days ago and will be selling before end of month, but not even a single review yet.
I'm torn between this and the 550D as well. Both have good and bad points for me. It looks like a nice well thought out case.
I'd love a window side panel on this case. BitFenix say that there isn't one as it's designed as a silent case.
The only thing I'm not too hot on is that the top has an open grill. I like the way the 550 has a solid cover incase you don't intend to use fans in the top. Won't noise "leak" out of the top? It just seeems odd to me that the sides are covered in sound damping material, but then the grill is left open?
