I have just bought a Bitfenix Merc Beta case and it only comes with 2no standoffs. However the screwholes inside the case are raised, does this mean i don't need to use them?
For an ATX motherboard installation you don't use risers but rather bumped up bits of the motherboard tray with tapped holes in them. The center riser is actually a pin and holds the motherboard in place while you add screws to all the other holes.
