BitFenix Neos Case
28 Jan 2011
Hey guys,
After deciding to keep my current setup and upgrading late on in the year, I have made the decision to change to a quieter and smaller case, along with a CPU AIO cooler.
How is this case? Will it be sufficient for my 1070 and 8350 with AIOC?
RTJ
Cable management is not great. Barely any room to put cables behind motherboard tray
What's your budget for the case? There may be an alternative
It will be suitable, and it is quite well made, but you might find something better
hey, yeah the more i looked at that it seams a little close for comfort. really considering a : Game Max Silent Sound Proofed Gaming Case for PC.
anyone with experience on this? seems a good bang for buck??
RTJ
I had the neos for a while, it's a neat looking case but is a nightmare to cable manage in. It's not the best laid out either. But it's £30 or thereabouts so you can't complain that much.
I've built in the s340 and currently using the p400s, both are infinitely better for around £50. It's a large percentage increase over the neos in real terms because both are so cheap but it really is worth it, the p400 is the best case I've had in a long time and we'll worth a look.
been taking a look at the p400, nice looking case. how is it compared to the neos for cable management? looks tenfold better.
RTJ
Night and day. The price has gone up since I got it for £53 but it's still worth the extra.
The fan controller, noise dampening, led's, cable management and general build quality are all far better than the neos. All three cases you'll be happy enough I think, but the p400 and s340 are much better.
