Bitfenix Nova TG
22 Oct 2006
Isle Of Lewis
Hey all, just ordered myself one of these for my budget build. However can't find any info on what connectors the supplied fans come with? are they 3 pin/4pin or what?
I only have the one jumper on my board so just trying to find out if I need to get a splitter or are they just molex and need to just get 'proper' fans.
Thanks!
I just had a look at the pictures and it looks like at least the rear fan has both a 4 pin and a molex connector, but I don't know if just one is needed or both so it might be best to just replace both fans if you don't want any molex connected fans in your system.
Yea I think I'll just have to go that route anyway... Usually 'free fans' will tend to be on the more budget side anyway.
Thanks for response!
