Hello
normally i don't do small pc build but i fancy a change and was looking to use a BitFenix Phenom MATX case for a MATX build
thinking of fulling populating the fan spaces as well as use a Corsair Hydro H90 140mm as the base of the main CPU cooling
anyone got one of these cases and used a similar CPU cooler in it??
hoping to maybe build one of these with a SSD and a couple of 3.5 inch HDD for storage before the end of the year and was looking for some advice and help as never did small pcs before
also if it helps i was looking at the Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor as the brains of the small beast
any help ideas or that is greatly helpful
WobblerJW
WobblerJW
