Bitfenix Phenom M Build
I really like this case , would love to order one so i can have my mini itx used with a corsair H80 ive got. But the no optical slot is killing it for me atm. Shame , i have the prodigy already but dont like it with the legs and stuff.
Am in the same boat.
But I then think how often do really need or use a optical drive, plus external USB drives optical are quite cheap
Hi guys, thanks for the comments.
The side panel was custom made with an industrial metal cutter (not a dremel + jigsaw) which is why the cut was clean enough not to need rubber edging. Really happy with it.
In terms of the optical drive, i havent had one hardwired into my pc for ages. I only use them if someone buys me a game on dvd - for this i have an external usb slimline dvd which works fine (you can even boot from them).
installing an optical drive into a gaming pc is just not necessary nowdays - all they do is create a lot of noise, freeze your pc sometimes and take up space.
Even if i had wanted one in this build, there wasnt enough space.
Here is a video i made of the build, it may help give you an idea of how much space there is inside the case:
I'm using the Asus Gtx 680 Direct CU II OC
temps are 27-31c idle, 80 on load. This is with GPU fan speed locked to be ALWAYS at 20%, so the card is pretty much silent during all games which is good.
Having 2 intake fans blowing straight on to the card really helps
I am impressed with the cooling in this case - for GPU cooling it is excellent.
I will need to make 2 mods to improve the airflow however:
1. Create a heat shield on the bottom of the case between the PSU exhaust and the 2 intake fans. When the PSU heats up the intake fans draw in a lot of hot air. Perhaps a better PSU than mine would also help (my PSU is terrible)
2. I will need to open up those side ventilation areas on the side of the case - there is actually solid plastic under that mesh, except for a few sporadic holes which is crazy from a design point of view.
