Bitfenix Phenom M build
Status
Not open for further replies.
yeah its a bit cramped but i just about managed to make it look neat - I love the fact that you can put the most powerful components in such a small case and a window shows this off. Without the window, people may mistake it for a mid range pc , god forbid!
A decent PSU with better looking cables would help but all the best ones (like the XFX Black) have the cable plugs right where the GPU hangs over the PSU (yes, my GPU is ridiculously long).
here is a video i made of the build to demonstrate just how blinking cramped this case is to work in:
I think that this case would look great as a media PC but it doesn't have an optical drive bay which may be a problem
It does bring an optical drive bay? You mean it's not visible/accessible unless the front panel is removed? Or that you had to remove it to fit the 240mm rad?
Very nice droid by the way. ;)
Status
