Bitfenix Prodigy compatibility with Phantom Cards?
24 Dec 2011
Hi there guys i have a Phantom 560Ti card i want to use with a prodigy if at all possible (But its a huge cooler as your probably aware) does anyone know the exact size and do they fit
Measured card 45mm from the back side of my PCB to the edge of the plastic shround surrounding the HS
EDIT: Without surround its 43mm
Can anyone measure from there cards PCB to the side panel when its on and secure please? If i have that i can work out more
This is what i found:
My GTX 680 phantom would not fit inside a prodigy unless i removed the plastic surround around the cooler, and then it was up against the side panel, very close fit.
Looking at the 770, the cooler looks almost identical in height from pcb upwards compared to the 680 version.
They are very quiet though.
Seems just...But not ideal.
I mailed rich last night I found this too.. His is the revision 2 phantom though which I am led to believe are bigger due to removable fan
