Bitfenix Prodigy full size GPU AND 5 hard drives, how to add more storage.
8 Oct 2008
Hull, East Yorkshire
I don't know if this had been posted before but I didn't see it. If you rotate the flexcages around you can have your cake and eat it. Unscrew the bottom, rotate, rotate middle and then rotate the bracket under the ODD.
I love this case but always hated only having two drives, now I can have all five drives adding more storage. The GPU touches the metal of the middle cage so you should put cardboard as protection between the GPU and cage. My 5870 has a plastic back on the PCB so I didn't have to. Now I just need to buy some sata cables and route them to the esata port at the back, potential for up to 15gb using 3tb drives in this case plus another 3tb if you use the ODD bay 5.25" to 3.5" adaptor.
