Ahoy hoy folks,
The other half is looking at changing her current case from a rather bland case from a weekly deal here about two years back.
She's pretty settled on this case, but I wanted to double check the cooling options for the case and so on.
Current spec (if it helps is)
Mobo: Gigabyte ga-78lmt-s2p MATX
CPU: AMD FX F4130 (stock cooling fan)
GPU: Asus Strix GTX 960
PSU: Corsair cx 430.
I'm looking at adding in a Corsair Hydro H55 at the top of the case for extra cooling. Also want to add in a few fans for it too as the ones she has are quite loud.
Thanks all
Thanks all
