*** BITFENIX PRODIGY MINI ITX CASE WINS EDITORS CHOICE AWARD - PLAY3R ***
11 Dec 2005
Cheshire
The almighty BitFenix prodigy Mini-ITX Case has been reviewed by Play3r and recieved the "Editor's Choice" Award!
"In conclusion, this case is nearly perfect for those people wanting to build a competent Mini-ITX gaming system. With brilliant support for air and water cooling, stylish design available in a range of colours, admirable cooling and acoustic performance" - Play3r
Read the full review here.
BitFenix Prodigy Mini-ITX Cube Case - Magma Orange @ £69.95 inc VAT
Meticulously crafted and beautifully engineered, Prodigy redefines the Mini-ITX chassis. The compact housing is suspended by handles made with BitFenix FyberFlex™ Composite for easy portability and maximum shock absorption. The spacious internals give you the flexibility to install up to five 3.5" hard disks or no less than nine SSDs. The modular FlexCage™ can also be removed entirely to fit long graphics cards and water cooling radiators up to 240mm in length, and a choice of Midnight Black or Arctic White with available interchangeable face plates mean Prodigy will suit your individual style. With tool-free convenience, two USB 3.0 ports, filtered intakes, and proprietary BitFenix SofTouch™ Surface Treatment, Prodigy is the compact case with no compromises.
- Beautifully Compact – Mini ITX dimensions with clean modern styling
- Unmatched Flexibility – Supports long graphics cards and up to 240mm water cooling radiators
- BitFenix FyberFlex™ Composite Handles – For portability and shock absorption
- Maximum Storage Potential – Install up to five 3.5" or nine 2.5" SSDs
- BitFenix FlexCage™ - Modular hard disk cage can be completely removed for added flexibility
- Choose Your Own Style – Two color options and interchangeable face plates available
- SuperSpeed USB 3.0 – Two ports included for blazing file transfers
- BitFenix SofTouch™ Surface Treatment – Luxurious matte finish and soft feel
- Trouble-free Installation – Tool-free drive locking mechanisms, cable management and filtered intakes
- Dimensions (WxHxD): 250 x 404 x 359mm
- Motherboard Sizes: Mini-ITX
- 5.25” Drive Bays: x 1 (removable)
- 3.5” Drive Bays: x 5 (3 + 2 modular)
- 2.5” Drive Bays: x 9 (5 + 2 + 1 +1 )
- Cooling Front: 120mm x 2 (120mm x 1included) or 140/180/200/230mm x 1(optional)
- Cooling Rear: 120mm x 1 (included) or 140mm x 1(optional)
- Cooling Top: 120mm x 2 (optional)
- PCI Slots: x 2
- I/O: USB 3.0 x 2, HD Audio
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: FyberFlex™ Composite handles, SofTouch™ surface treatment, filtered intakes, tool-free drive locking
Only £69.95 inc VAT.
ORDER NOW
I understand that, products you guys sell win some kind of award every day, just found it weird that you decided to show off the case because it won an award and no other product..
It's called marketing, people might be more inclined to purchase something that has won awards, that's why this forum is here to help sell products.
Don't like it, don't read it.
Possible Build?
I'm after a bit of advice re the Bitfenix Prodigy.
I have seen a couple of systems using this case with an overclocked Core i5, but I am looking at a possible build using an AMD FX8-8320 or 8350 and AMD HD 7800 or R9 270 series graphics card.
I wondered if this case would fit all the above and a 3rd party cooler (probably air) and mobo you would recommend for a potential mild overclock?
Also would this require low profile RAM, I am thinking of 8 GB of DDR3 @ 1600Mhz ?
Problem is there are no good mATX AM3+ boards up to the task of handling a FX 8320/8350 when overclocked last time I looked.
