Potentiall looking to put together an ITX build, only part im not so keen on are the case "feet". Want to look at taking the feet off, maybe trimming them down to cover the gap that is left along the bottom of the side panels and putting some feet on it.
Just having some trouble finding some nice chunky feet to bolt on the bottom (that dont cost too much), the case needs to be raised a reasonable amount for the PSU intake filter on the bottom.
Any suggestions are welcomed.
. I can fit my hand underneath the case, which is something I cannot do with my main case.
