BitFenix Recon
Not at home to verify but I think it just turns off the screen. Never really needed to turn it off :)
It would only be needed late at night when watching films with the mrs.
How do you find it as a unit & how many fans do you have connected?
Just tested and yep screen goes off only, fans stay running.
You can turn fans off by manually adjusting them through the screen, packaged software or Phoebetria.
I only have three fans connected although it can take 2 or 3 standard speed fans per channel if you are willing to sacrifice a small percentage of top end speed.
The only gripes I have with the unit are that sometimes the fans speed up and down by 100 RPM or so for no apparent reason, something which I hear that Phoebetria apparently fixes. Also I wish the backlight colour was changeable. I even tried to mod the LEDs but they are so firmly rooted in the light pipe that I was scared to remove them.
