** BITFENIX REVEAL THEIR SECRET FORMULA **
OcUK Staff
26 Nov 2014
Stoke
Launching today, we have the brand new Formula PSU range from Bitfenix. Following on from the success of the Whisper M, Bitfenix have introduced the Formula series as a more cost effective option, without compromising on quality. The Formula comes in 4 wattages from 450W - 750W, with pre-wired cabling. They are produced by CWT, same as the Whisper M, and have very similar technical features. For a start, a quiet 120mm FDB fan is supplied as standard, that is capable of 500RPM operation, along with a custom fan grill design for low resistance. This means that at around 60% load, the Formula only produces 18dB(A). The technology inside will please the PSU purists, with Active PFC and LLC resonance conversion on the primary range, along with DC-DC down conversion on the secondary. Indeed, the Formula actually has a custom PCB design, rather than relying on a manufacturers existing design. Capacitor use is Japanese 105 degree electrolytic & polymer solid throughout.
The full suite of protections (OPP, OTP, OVP, UVP, SCP, OCP, SIP & NLO) prove even further how impressive the Formula series are for the money. Added to that, the Formula series comes with a 5 year warranty as standard, along with comprehensive connector support throughout the range. I think Bitfenix have done very well to get this amount of quality and features into the Formula series and maintain a good pricepoint. Stock will be available in approx 10-14 days. Preorder now!
Bitfenix Formula Series 450W 80 Plus Gold Power Supply @ £59.99 inc VAT
80 Plus Gold power supply with four +12 Volt rails, Extensive failsafes, DC-DC technology and extra quiet 120 mm fan.
Only £59.99 inc VAT.
ORDER NOW
Bitfenix Formula Series 550W 80 Plus Gold Power Supply @ £66.95 inc VAT
Only £66.95 inc VAT.
ORDER NOW
Bitfenix Formula Series 650W 80 Plus Gold Power Supply @ £74.99 inc VAT
Only £74.99 inc VAT.
ORDER NOW
Bitfenix Formula Series 750W 80 Plus Gold Power Supply @ £82.99 inc VAT
Only £82.99 inc VAT.
ORDER NOW
I have an old rig needs a new psu fx-6300, gigabyte ga-990fx gaming sli, asus 7870 direct ii you and 120 ssd and 1tb hdd. wud the 750 manage to run this?
cheers
Great to see some decent, cheap gold rates power supplies which also seem quiet. Nearly at the £1 per watt mark.
