**BITFENIX RGB SPECTRE RANGE IS RELEASED**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
Bitfenix have been making fans for a very long time so they know what makes a good fan that meets the market. Following the success of the spectre fans they have decided to add RGB lighting which is where the market seems to be heading. As much as we see RGB everywhere and try to avoid it in most cases it just makes sense to take it on as the colour options are so vast and unrestricted.
Bitfenix have released 120mm, 140mm, 200mm and 230mm as shown below:
BitFenix Spectre Pro RGB Fan - 120mm @ £12.95 inc VAT
Bitfenix Pro RGB Fan, 120mm, 1200 RPM ±10%, 56.22 CFM ±10%, 18.9 dB(A), Asus AURA sync
Only £12.95 inc VAT.
ORDER NOW
BitFenix Spectre Pro RGB Fan - 140mm @ £15.95 inc VAT
Bitfenix Pro RGB Fan, 140mm, 1200 RPM ±10%, 86.73 CFM ±10%, 22.8 dB(A), Asus AURA sync
Only £15.95 inc VAT.
ORDER NOW
BitFenix Spectre Pro RGB Fan - 200mm @ £18.95 inc VAT
Bitfenix Pro RGB Fan, 200mm, 900 RPM ±10%, 148.72 CFM ±10%, 27.5 dB(A), Asus AURA sync
Only £18.95 inc VAT.
ORDER NOW
BitFenix Spectre Pro RGB Fan - 230mm @ £19.99 inc VAT
Bitfenix Pro RGB Fan, 230mm, 900 RPM ±10%, 156.27 CFM ±10%, 25.6 dB(A), Asus AURA sync
Only £19.99 inc VAT.
ORDER NOW
BitFenix Spectre Pro RGB Fan Command Kit - 120mm @ £16.99 inc VAT
Bitfenix Pro RGB Fan, Comes with Controller, 120mm, 1200 RPM ±10%, 56.22 CFM ±10%, 18.9 dB(A), Asus AURA sync
Only £16.99 inc VAT.
ORDER NOW
BitFenix Spectre Pro RGB Fan Command Kit - 140mm @ £19.99 inc VAT
Bitfenix Pro RGB Fan, Comes with Controller, 140mm, 1200 RPM ±10%, 86.73 CFM ±10%, 22.8 dB(A), Asus AURA sync
ORDER NOW
BitFenix Spectre Pro RGB Fan Command Kit - 200mm @ £22.99 inc VAT
Bitfenix Pro RGB Fan, Comes with controller, 200mm, 900 RPM ±10%, 148.72 CFM ±10%, 27.5 dB(A), Asus AURA sync
Only £22.99 inc VAT.
ORDER NOW
BitFenix Spectre Pro RGB Fan Command Kit - 230mm @ £23.99 inc VAT
Bitfenix Pro RGB Fan, Comes with controller, 230mm, 900 RPM ±10%, 156.27 CFM ±10%, 25.6 dB(A), Asus AURA sync
Only £23.99 inc VAT.
ORDER NOW
ALL BITFENIX FANS AVAILABLE HERE
Hi, will the rgb for these run off the rgb port on my new motherboard (gigabyte aurus gaming 3) or is that port just for rgb strips?
Hi,
They work with the Asus Aura software so they will connect to the motherboards RGB port. I can't see why the software would not work using a gigabyte motherboard.
Any release date for these yet @Robbie_G ?
Looking to get 4 120's and 3 140's for my 303c as intake and radiator (I know, probably not best for performance vs the Vardars, but pretty!) but I'm at the point where I can't really wait much longer!
They have been shipped from Germany so hopefully within a week but it is the christmas holidays so not 100% sure.
Ah. Thanks @Robbie_G but I need to build 27th/28th/29th really.
Any recommendations for matching 4* 120 (3 rad 1 case) and 3* 140 (rad) fans which are available and will do Asus Aura Sync (and ideally daisy chaining)?
Ta.
