BitFenix Ronin Tower Case and H100
31 Mar 2013
Essex/london
Is the BitFenix Ronin Tower Case the cheapest case with sidepanel that fits and h100? Also does it matter which motherboard ill use i mean is there enough space?
I have the bitfenix ronin and my h100 fits fine in push configuration :) Could probably just fit in push/pull
how are you finding the case? im undecided atm between this and the air 540 but this one seems very good for the price especially as i am on a budget, any pictures would be lovely too if you dont mind :P
I too am looking to get this case but I am swaying more towards the Deepcool Pangu. The things that it has that the Ronin does not include:
Filtration for top mounted Fans.
Front filter not attached to Fans.
Better ventilation at front and top.
Case is also available in white.
Only downsides are that it does not have Windows like the Ronin and when I emailed Deepcool they said they don't have a UK reseller.
Aye sure i can soon do photos for you. I think its a lovely case personally!
Anything in particular you want just ask me :) I did a case review on this very forum if you go onto my posted topics it should be pretty recent
Excuse my ancient hardware
That looks nice mate, has anyone had any particular problems with the cass? How is cable management?
Is it possible for a push and pull with the h100? How do you have yours set up? I also noticed a fan next to the psu didnt know there was room there.
Yeh room for 120mm fan on bottom all filtered from underneath, Mines setup in push. I think it would all depend on your mobo, I could just fit push/pull in but it would be millimeters away from my fan blade.. i run an old amd setup my RAM is only LP stuff but the dimms are really close to the top of my board not sure if there still like that on all boards now
Well im def. getting this, it was either the ronin or the air 540 but since im on a budget ill go with the ronin, im in portugal atm so ill get back soon then i need to wait for a bank transfer abd make my built then. Seen some youtube videos too seems very good for the price. Will post pictures or make a project log thread. Cheers for the input!
GrimsbyLAD is your radiator inside the top panel or inside the case where the motherboard is and etc?
also just saw a video on youtube and you can set up a fan on top of the HDD bays?
also any ideas where i can buy different color micro mesh strips?
