bitfenix shinobi fan set up [help]
12 Dec 2013
Uk
Hello all,
So I've recently upgraded my pc and got the bitfenix shinobi (windowed) case.
I was just wondering your suggestions for a good fan set up.
I've currently got 2x140mm corsair fans, 2x120mm bit fenix fans( what came with the case) and a Intel water cooler (RTS2011LC) so this is taking up the back fan slot.
It would also help if you could say what should be taking cold air in and what will be pushing the hot air out.
Bit of a novice when it comes to this stuff!!
Thanks, Andrew.
