- 18 Oct 2002
- UK
I'm thinking this case might be for me, if someone with some more info can comment on:
Cheers
It's a slightly different case but I'm also worried about my cooler not fitting in?
As in this pic the space between the top of the motherboard and the top of the case is minimal, finding it hard to find reviews that measure this, or even photos of the cooler installed showing the overhang. Cooler is a Zalman CNPS10X Performa pretty much: http://www.overclockers.co.uk/showproduct.php?prodid=HS-046-ZA&groupid=701&catid=57&subcat=1395
My mobo seems to have the socket mounted fairly down on the pcb though, so perhaps not a worry?
Perhaps this thread needs a title change, didn't want to spam the forum! Perhaps: BitFenix Shinobi + CPU fitment questions
- If the fans are 3pin/4pinPWM/Molex ended
- If the side panels can be swapped over, move the window to the mobo side and just have the plain black one on show for 'business mode' running
Cheers
