bitfenix Shinobi rebuild cooling questions
26 Dec 2010
England
Okay guys here's the quick version, doing a system rebuild and want some good cooling, my brother however has pointed out some possible flaws, but anyway I will be using a Shinobi case and I want to have the two front fans pulling in the two at the top pulling out and one on the back pulling out. I was thinking of using a Thermaltake Frio or akasa Voodoo for the Cpu but apparently this setup could mess up air flow with the cooler causing issues, so what are your thought. Advice on the cooler and fans would also be greatly appreciated, I'm a bit lacking in the pc building know how. :confused:
