BitFenix Shinobi XL Range Expansion
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys!
I have added to our already excellent range of cases with the new BitFenix Shinobi XL with White and windowed versions!
Take a butchers. :D
BitFenix Shinobi XL Full Tower Gaming Case - White @ £119.99 inc VAT
We've taken our battle-proven Shinobi design and expanded it, creating a roomy, feature-packed full tower enclosure that will not only turn heads, but take them clean off. The larger size enables you to outfit your Shinobi XL with the latest fear-inducing hardware, including XL-ATX motherboards and the longest graphics cards. Shinobi XL can accommodate up to two 360mm radiators, making it ideal for water cooling enthusiasts. Four SuperSpeed USB 3.0 ports and the all-new BitFenix SuperCharge™ port keep your peripherals and mobile devices ready for battle, while the BitFenix FlexCage™ hard disk rack adds to the Shinobi XL's nimbleness. With three included Spectre™ fans, tool-free drive locking, filtered intakes and signature BitFenix SofTouch™ Surface Treatment, Shinobi XL is the chassis you need when vengeance is not enough.
- Dimensions (HxWxD): 570 x 245 x 557mm (ATX Full Tower)
- Motherboard Sizes: Mini-ITX, mATX, ATX, XL-ATX
- 5.25” Drive Bays: x 5
- 3.5” Drive Bays: x 7
- 2.5” Drive Bays: x 8 (using 3.5" drive bays and 5.25" adapter)
- Cooling Front: 1 x 230mm (included), or 3 x 120mm (optional)
- Cooling Rear: 1 x 120mm (included), or 1 x 140mm (optional)
- Cooling Top: 2 x 230mm (x 1 included), or 3 x 120mm (optional)
- Cooling Bottom: 2 x 120mm (optional)
- PCI Slots: 9.
- I/O: 1 x SuperChargeTM, 4 x USB 3.0, HD Audio
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: Superior watercooling support, FlexCage™, SofTouch™ Surface Treatment, filtered intakes, tool-free drive locking
- Maximum CPU Cooler Height: 193mm
- Maximum Expansion Card Length: 377mm (with HDD cage) / 492mm (with HDD cage removed)
- Maximum MB Tray Clearance (rear): 34.5mm
Only £119.99 inc VAT.
ORDER NOW
BitFenix Shinobi XL Full Tower Gaming Windowed Case - White @ £129.98 inc VAT
- PCI Slots: 9.
Was [OLDPRICE] Inc. VAT
Only £129.98 inc VAT.
ORDER NOW
BitFenix Shinobi XL Full Tower Gaming Windowed Case - Black @ £129.98 inc VAT
- PCI Slots: 9.
ORDER NOW
I have a Collossus, white windowed (see my build log in my signature), I'm tempted to move to the white windowed XL.
