** BITFENIX SHOGUN - TOTAL AWE **
OcUK Staff
26 Nov 2014
Stoke
In stock now, we have the brand new flagship Bitfenix Shogun Midi Tower Case. The Shogun has been engineered with direction from renowned enthusiasts to produce a case that's big on desirable features. Externally the Shogun sports dual tempered glass side panels, curved aluminium top and bottom panels and a premium finish throughout. Internally, the Shogun offers 'Quick Custom Design Technology' with modular design for high end hardware, allowing for E-ATX motherboards to be installed, with an E-ATX shield plate supplied for efficient cable routing. Radiator support is good, with up to 360mm supported on the top panel, 280mm radiators on the front and 140mm at the rear.
Hard drive cages supporting up to 6 HDD's or 8 SSD's can be easily removed and moved to any point of the mounting rail depending on preference. There is a pair of SSD chroma modules which are Asus Aura certified, which are mounted in a prominent position in the chassis and can be quickly removed as needed. 410mm VGA Cards, 175mm CPU Coolers and 250mm PSU's can be supported. It is nice to see Bitfenix releasing some great case designs again. Stock is available now!
Bitfenix Shogun Midi Tower Tempered Glass Gaming Case - Black @ £144.95 inc VAT https://www.overclockers.co.uk/bitf...mpered-glass-gaming-case-black-ca-228-bx.html
With the input from some of the world’s renowned enthusiasts we have developed the BitFenix Shogun be an extremely desirable chassis with many desirable features.
Only £144.95 inc VAT.
ORDER NOW
not really liking this... are there any more new tempered glass cases coming out before xmas, else it looks like the pro M when it comes back in stock
Not before Xmas. Pro M Glass is a solid choice.
Pro M Glass awaits
It is an elite-tier case
You will enjoy it
Phanteks Sales Rep Haiku - 2016
