I bought a 120mm BitFenix Spectra Pro Blue LED fan and on 2 occassions, it appears to not spin up. I can jump it by giving the blades a poke and it's fine.
Maybe your fan voltage is too low to get it started? Is it mounted on a fan controller? That being said both the Spectre Pro non-LED I have here start up at fairly low voltage.
Low is probably too, well, low to get the fan started. What you need is a fan controller that starts your fans up at full speed and then settles down to slow after a few seconds, or just do it yourself.
