Hi all,
*title should say 200mm*
I just bought these fans for my case and I am just installing them when I notice that, for this case, they can only be installed on the front if you want the fan to extract air! I cannot install them to intake air! On the original case fan, the screw slots are the same width as the fan so the screw can actually hold onto the fan, but on the Spectre's, the screw hole is only on one side.
Some pics:
normal fan that came with the case on the right and new Spectre fan on the left
Any ideas?
Some pics:
Any ideas?
