You asked, They listened
Bitfenix, the number one name in Chassis and Cooling have released their superb Spectre PRO range with Green LEDs.
These awesome looking fans have the spec lists to match.
Grab yours now!
BitFenix Spectre PRO 120mm Fan Green LED - Black @ £11.99 inc VAT
Following the success of our Spectre™ LED Fan Series, Spectre Pro™ LED ups the ante with an all-new design and enhanced performance. The high pressure and CFM design produces wicked cooling and is also perfect for watercooling setups. Its dual frame construction not only looks great, but also helps to dampen vibrations that cause unnecessary noise. Reinforced fan blades prevent warping at high RPM levels, while focused airflow ensures cool air can reach all of your installed components. With FDB technology for low noise and long life, multiple color options, and on-the-fly light switching, Spectre Pro LED is the new gold standard in performance case fans.
Harness the fury with the Spectre Pro LED Fan Series.
- Dimensions (mm): 120x120x25mm
- Current (A): 0.18A ±10%
- Speed (RPM): 1200 RPM ±10%
- Air Flow (CFM): 56.22 CFM ±10%
- Air Pressure (mmH2O): 1.24 mmH2O
- Noise (dB-A): 18.9 dB(A)
- Colour: Green
Only £11.99 inc VAT.
ORDER NOW
BitFenix Spectre PRO 140mm Green LED - Black @ £13.99 inc VAT
- Dimensions (mm): 140x140x25mm
- Current (A): 0.25A ±10%
- Air Flow (CFM): 86.73 CFM ±10%
- Air Pressure (mmH2O): 1.38 mmH2O
- Noise (dB-A): 22.8 dB(A)
- Colour: Green
Only £13.99 inc VAT.
ORDER NOW
BitFenix Spectre PRO 200mm Green LED - Black @ £14.99 inc VAT
- Dimensions (mm): 200x200x25mm
- Current (A): 0.33A ±10% Speed (RPM): 900 RPM ±10%
- Air Flow (CFM): 148.72 CFM ±10%
- Air Pressure (mmH2O): 1.26 mmH2O
- Noise (dB-A): 27.5 dB(A)
Only £14.99 inc VAT.
ORDER NOW
BitFenix Spectre PRO 230mm Green LED - Black @ £16.99 inc VAT
- Dimensions (mm): 230x200x30mm
- Current (A): 0.41A ±10%
- Speed (RPM): 900 RPM ±10%
- Air Flow (CFM): 156.27 CFM ±10%
- Air Pressure (mmH2O): 1.81 mmH2O
- Noise (dB-A): 25.6 dB(A)
Only £16.99 inc VAT.
ORDER NOW
Grab yours now!
- Colour: Green
ORDER NOW
- Colour: Green
ORDER NOW
ORDER NOW
ORDER NOW
