** BitFenix Spectre Xtreme Fans **
OcUK Staff
12 Apr 2008
OcUK HQ
Hi Guys
Today we are happy to announce the release of the new Spectre Xtreme fans from Bitfenix.
The BitFenix Spectre Xtreme is a versatile high-performance fluid dynamic bearing fan, with built in vibration damping
The rim and blades work effectively in unison to provide high air pressure, making the Spectre Xtreme optimal for use on radiators or CPU coolers.
The BitFenix Spectre Xtreme comes equipped with with or without LEDs depending on your personal preference.
BitFenix Spectre Xtreme 120mm Fan - Black @ £8.99 inc VAT
The BitFenix Spectre Xtreme is a versatile high-performance fluid dynamic bearing fan, with built in vibration damping – catering for PC enthusiasts in general, and users of water cooling in specific. The form factor is a standard 120x120x25mm, with a total of five different color options available, four with LEDs.
When it comes to looking unique, the Spectre Xtreme has you covered. The rim and blades work effectively in unison to provide high air pressure, making the Spectre Xtreme optimal for use on radiators or CPU coolers. The mounting holes are placed in blocks of TPU, making the mounts flexible yet stiff, eliminating vibrations.
High-speed operation, or low-speed, low-noise operation? Why not both? The Spectre Xtreme lets you choose yourself. The maximum possible airflow is achieved with 12V - 2000 RPM, 66CFM and 2.74mm/H2O, but it will operate with as low input voltage as 5V – resulting in 950 RPM and tranquility. The choice is yours.
To LED or not to LED – the choice is once again yours. The black Spectre Xtreme comes without any installed LEDs, while the Blue, Green, Red and White ones do. Special care has been taken to match the Green LED with the light emitted from NVIDIA GeForce GTX stock coolers. Even with the LED versions, you can easily turn the LEDs off with the jumper cable.
Low internal resistance is important – so the Spectre Xtreme utilizes Fluid Dynamic Bearings. This means that more of the power fed to the fan motor will be transferred to actually rotating the blades, lower noise levels, as well as a longer life expectancy thanks to optimal lubrication of the bearings. The technology was first utilized in hard drives, and has become a must-have feature on any high-end PC fan in latter years.
Specification:
- Dimensions: (W x D x H) 120 x 120 x 25mm
- Fan Speed: 950-2000 RPM (±5%)
- Airflow: 66 CFM at 2000 RPM (±10%)
- Air Pressure: 2.74mm H2O at 2000 RPM (±10%)
- Operating Voltage: 5-12 VDC (±5%)
- Power Consumption: 3.36W at 2000 RPM, 0.28A 12VDC (±10%)
- Noise Level: 30dB at 2000 RPM (±10%)
- Bearing Type: Fluid Dynamic Bearing, FDB
- Accessories: Anti-vibration grommets x 4
- Case screws: x 4
- Radiator screws + washers: x 4
- 3-to-4 pin power adaptor
Only £8.99 inc VAT.
ORDER NOW
BitFenix Spectre Xtreme 120mm Fan Blue LED - Black @ £11.99 inc VAT
Specification:
- Case screws: x 4
Only £11.99 inc VAT.
ORDER NOW
BitFenix Spectre Xtreme 120mm Fan Green LED - Black @ £11.99 inc VAT
Specification:
- Case screws: x 4
ORDER NOW
BitFenix Spectre Xtreme 120mm Fan Red LED - Black @ £11.99 inc VAT
Specification:
- Case screws: x 4
ORDER NOW
BitFenix Spectre Xtreme 120mm Fan White LED - Black @ £11.99 inc VAT
Specification:
- Case screws: x 4
ORDER NOW
These will be a superb performance option for people looking to add colour to their system but wanting a huge amount of performance.
No other sizes announced right now but probably in the future.
They are better than the pro if you are looking for outright performance.
No ETA right now but they shouldn't be too long.
I have a boxed kelvin T12 witch has push pull fans, will a single one these fans be ok for this, I have been told on here before that push pull is a waste of time anyway
they should be fine, they are advertised to suit radiators and come with screws
"Radiator screws + washers: x 4"
I am planning to put on my Fractal AIO
