BITSPOWER FITTINGS HELP !
31 Mar 2014
I'm looking to order some bitspower G1/4, 1/2"ID (3/4"OD) black sparkle compression fittings, but on the website in the description of the fittings it doesn't tell you what size they are.
So could someone list all the different fittings in that size so I know which ones to buy? also I need a male to male fitting to connect pump to res.
first time at watercooling :)
Thanks
Bitspower fitting is pretty rare in the UK, so your best bet would be either order it from Netherland (HighFLOW) or the US.
Or you can choose to use Monsoon or EK (cheaper and made in Slovenia)
