BITSPOWER FITTINGS!
11 Dec 2005
Cheshire
We have got some sweet new Bitspower fittings instock!
Bitspower Matt Black 7/16" Compression Fitting (G1/4") - BP-MBCPFD-CC6 @ £7.99 inc VAT
Bitspower fittings are the finest fittings money can buy. These 7/16" fittings are perfectly finished in Matt black to make any watercooling loop look sleek and refined.
These fittings are ideally designed to fit with 7/16" ID 5/8" OD tubing.
Only £7.99 inc VAT.
ORDER NOW
Bitspower 1/2" High Flow Matt Black Barb (G1/4") - BP-MBWP-C01 @ £3.25 inc VAT
Bitspower fittings are the finest fittings money can buy. These 1/2" fittings are perfectly finished in Matt black to make any watercooling loop look sleek and refined.
These fittings are designed to fit with 7/16" ID tubing without the use of tubing clips, or can be used with 1/2" ID tubing for use with tubing clips.
Only £3.25 inc VAT.
ORDER NOW
Bitspower Matt Black Rotary 45 Degree angle fitting (G1/4") – BP-MB45R @ £11.48 inc VAT
Bitspower fittings are the finest fittings money can buy. These 45 degree rotary fittings are perfectly finished in Matt black to make any watercooling loop look sleek and refined.
These fittings are designed to be used in conjunction with any G1/4" tread fitting. Use of these fittings allow for tighter bends and therefore cleaner and higher flowing loops.
Only £11.48 inc VAT.
ORDER NOW
Bitspower Matt Black Stop Fitting (G1/4") BP-MBWP-C06 @ £2.58 inc VAT
Bitspower fittings are the finest fittings money can buy. These G1/4" Stop fittings are perfectly finished in Matt black to make any watercooling loop look sleek and refined.
These fittings are designed to be used in conjunction with any G1/4" tread opening.
Only £2.58 inc VAT.
ORDER NOW
Nice! Any chance that OCUK be stocking a complete range in the future? In addition to a more comprehensive watercooling catalogue?
These fittings are amazing, tempting me to do a watercooling loop in my new rig, these would fit nicely. :p
They look amazing! Would be much better than my silver ones :D
Quick question, would you recommend barbs over compressions, or vice-versa? Cheers :)
