- 4 Dec 2012
Need help figuring out the correct way up this tube reservoir should be when installing it into the case, my guess is the best way to mount it would be the three holes go on top with the tube (on top) as inlet and the other two holes on top are for fill port and the led light, then the vortex fitting goes on the bottom inside as the outlet from the reservoir to the pump, just need feedback on if this is correct or wrong, or can you do it any other ways, thanks
Picture of tube reservoir
http://www.overclockers.co.uk/showproduct.php?prodid=WC-321-BP&groupid=962&catid=2133
